1971 911 Targa jacking points
Does anyone have a diagram of the proper jacking points for a 1971 911 Traga?
From our our pals at the Pelican BBS: http://forums.pelicanparts.com/showt...jacking+points with special thanks to Bill Verburg.
Jack at the x's. https://forums.pelicanparts.com/uplo...1133297845.jpg |
A couple of those jack points coincide with the location of the front oil cooler hard lines. Unfortunately, the hard lines aren't sturdy enough to withstand a floor jack underneath it and 1000 lbs of chassis on top.
Use these lift points carefully if using a chassis lift. If using a floor jack, invest in a jack pad that fits into the factory jack slot along the lower rocker panel, then place appropriate jack stands under the torsion bar tube (rear) and the front mount of the torsion bars (front). Sherwood http://members.rennlist.org/911pcars |
Originally Posted by 911pcars
(Post 4417992)
Use these lift points carefully if using a chassis lift. If using a floor jack, invest in a jack pad that fits into the factory jack slot along the lower rocker panel, then place appropriate jack stands under the torsion bar tube (rear) and the front mount of the torsion bars (front). Sherwood http://members.rennlist.org/911pcars _ _ _ _ _ _ _ _ _ 1971 911T Targa; aka "The Monument" |
Originally Posted by Mike777
(Post 12502449)
Which points correspond with the run of front oil cooler hard lines? The points at C?
_ _ _ _ _ _ _ _ _ 1971 911T Targa; aka "The Monument" Sherwood |
