bolts on the ac compressor?
What is the correct tension (deflection) on the AC compressor belt?
No one? In another forum the reply was reasonably tight, which is vague. I am used to 1/2" which may be too loose.
Then drive the car with AC on for a few minutes.
If belt slips when clutch is engaged then you tighten it a hair
until slip (squeal) stops.
