74 CIS Fuel Line ?
8th Gear
Well, I'm just about ready to put the motor back into my car but I want/need to replace some of the fuel lines.
In particular, I want to replace the rubber return line from the fuel distributor, the rubber return line from the WUR, and the plastic supply line from the filter to the fuel distr.
-What type of fuel line do I need to use to replace the rubber return lines? Should they be high pressure or is reg. fuel line OK?
-The plastic supply line on the 74 CIS is heated/crimped onto the barbed nipple on the fuel distr. Could I cut this line and replace with a high pressure rubber line that is clamped onto the nipple or does it need to be replace with another plastic line?
Please help...I want to get on the road ASAP!!!
-Dave
-Dave
Dave, if you're interested, I have a FULL set of steel lines from my 1982 911SC that will work perfectly for your application, as the CIS lines are the same fitment, although the earlier ones were plastic.
I'll sell them dirt cheap.
