How to: change alt warning lite in dash
Before I start tearing things apart...
How do you change the bulb in the dash for the alt/battery dummy lite?
Thru the front trunk or does the gauge pull out? Any tips as I have not done this before!
86' Carrera
thanks!
86' Carrera
thanks!
Team Owner
the gage puls straight out the front.. if it doesn't budge see if you can get any of the others , reach through the hole and pop it out from the back. That is about it .. I think it is a weird bulb though .. not sure...
