Windsheild Trim
Poseur
No. That stuff is extremely delicate and you will wind up bending it if you try to remove it. The safest way to remove windshield trim is by acknowledging that you cannot save the rubber so you have to cut it apart. Then the trim is intact. You have to use a bunch of ru-glide (rubber lublicant) to reinstall that stuff. Once you bend it,--you're in trouble.
Just recently replaced the window seal and painted the trim ad reinstalled it.....took two people and about an hour of fighting with the trim and seal. If your seal is ok...paint it on the car!!!
