911 wont turn over
911 wont turn over
I checked everything even replaced the battery which was bad to begin with i and it still won'tturn over.Its not making a clicking souund..its almost as if the starter is done for.When I jump the battery it starts...can someone help me srt this out. Its frustrating.DME is fine as well as the DME relay...
thanks
bob-'88 911 cab
thanks
bob-'88 911 cab
Team Owner
Something not right here . When you jump the battery all you are doing is replacing the battery. The Battery you put in sounds to be no good unless there is more to the story .....
Can we clarify something.
"Wont turn over" ... to ME means, starter will not turn engine at all ...is that the problem? But then you say, "When I jump the battery, it starts?" So with a boost, the car starts and runs ok?? More info. please.
May be as simple as a good cleaning of the battery cable ends and being SURE the new battery is fully charged.
I tried jumping the brand new battery right now which tested GOOD when I bought it this morning and still nothing. I took the battery cables off the new battery and jumped the other cars battery directly to 911 cables and still nothing....HELP!!!@#
