can anyone identify this 66 911 from pics ?..
ANy ideas I have very limited info at moment, but its 66..and has a 911 badge , thats the limit of my ability....any clues guys ?..what this may be and price ranges ?
Cheers
Cheers
It has an "S" deco strip on the front bumper, the wipers are installed backwards and the trunk lid doesn't fit well. What's the VIN of this car, it could be a '65. Right side mirror is really unusual, be sure to check that you can see it from the driver's seat, they're usually installed wrong. Is the car just out of the body shop? The body color seen behind the horn grille is a tip off.
It would help to have a pic of the dash face to the left of the steering wheel, a pic of the engine compartment, slightly angled so I can see the outboard side of the carbs, a pic of a door panel including the inside of the door, a shot of the front trunk compartment, and anything that you see that you might have a question about. Obviously, because rust can be an issue with early cars, you must arrange for a PPI with someone who is familiar with the older 911s. Records should be investigated carefully (trans overhaul, clutch replacement, engine work, maintenance, etc.) that can give you clues as to the actual mileage.
More information provided..Im being drip fed, so sorry bout that, but this is kinda fascinating too, this is my latest tidbit
"The driver door plate read: Made in West Germany
Karosserie
No. 304010
Kunstharzlack
Forbton 6604
Under bonnet read: Fahrgestell- Nr
304010
GVW 1400"
Karosserie
No. 304010
Kunstharzlack
Forbton 6604
304010
GVW 1400"
