Oil Tank Drain Plug-----Grip of Death?!
Team Owner
You are okay ... but definitely use the note .. as far as you hoses go it will all depend which ones , as long as they are not hard lines you should be fine. Just take your time and see if they realy need replacing.
Good job changing the oil! No real good way to check the rubber bushings in your a-arms unless you take them out so make sure you really want to do that. I changed mine out with polybronze bushings. One thing you might want to consider is if you ever do change the bushings in the future, you will have to get the car realigned.
My PPI mechanic a year ago said my bushings needed to be replaced, but in retrospect I don't know how he came to that conclusion. They probably would have been ok. Now if I want to change my front torsion bars in the future, I would have to get the car realigned again afterwards.
Keep up the good work!
"I suggest disconnecting negative battery lead whenever...." and poking holes in the tires just in case. (sorry, couldn't help it) Isn't a note enough? Unless you have either 1) knockoff post-its with inferior glue or 2) ne'er-do-wells that may sabotage the whole thing while you're not at home. If you store the battery at a neighbor's house, who could guess which neighbor? (sorry again)
Originally Posted by KCPSG
once you get it out, install one of these...makes oil changes very nice. http://www.fumotovalve.com/
http://www.mainelycustombydesign.com...omponents.html
Worse case I would use vice grips on frozen/stripped plug on oil tank.
Notes 'should' work but the wife may sometines mis-interpet/ignore. I had a vehicle driven off jackstand with front wheel off when I went ot get a brake disc.
