start-up problems
3rd Gear
Sometimes my 3.2 1995 carrera won't start.
Yesterday I turned off the engine after an one hour drive. After a few minutes I tried to start it up again, but it wouldn't start. Later that day the problems were solved...
This morning it wouldn't start at all.
Somebody has a clue?
Thanks!
Lauke
'85 Carrera 3.2
Thanks!
Lauke
'85 Carrera 3.2
Lauke,
Your description of the starting problem indicates that your problem occurs at random times.
The first thing I would check is the DME Relay which is under the driver's seat (next to the DME control unit). Most 3.2 Carrera owners carry a spare DME relay because when it goes bad, the car doesn't run. Many times the DME relay will start going bad by producing sporadic starting problems. Anyway, that's where I would start looking.
Regards, Bruce
Regards, Bruce
Technical Specialist
Lifetime Member
Lifetime Member
Lauke,
Bruce's comment on the DME are spot on. If that doesn't fix it, you need to give us more details on how it wouldn't start....starter wouldn't spin? Engine turned over but wouldn't catch? etc.
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
Hearing so much about the DME relay, it looks like a wise option to carry one as a spare part.
Is it a "special" relay, or does it have any "standard" specifications, so I can buy a cheap replacement in any hardware store?
Lifetime Member
Lifetime Member
<STRONG>Hearing so much about the DME relay, it looks like a wise option to carry one as a spare part.
Is it a "special" relay, or does it have any "standard" specifications, so I can buy a cheap replacement in any hardware store?</STRONG>
