lug bolt replacement
RL Technical Advisor
Hi Bruce:
Are you referring to the studs that you attach the alloy nuts to?
911's use studs and nuts; 996's and later use lug bolts,.....![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
If so, you must pull the stub axle to install new wheel studs and that requires that the axle shaft assembly be removed and a puller used to extract the stub axle. Then, you press out the old studs and press in the new ones.
