Oil Leak Help
My 80SC just started leaking a little on the left side back towards the firewall behind the last injector. IM just trying to figure out whats in that area there seems to be two oil/vacuum lines coming down to where I can see the leak one line seem's to be coming from the accumulator the other seem to be running down from the air box, just wondering if anybody can give any input as to what these lines are and how big of a fix am I looking at vehicle runs strong has 236k miles no other leaks are present. This started this past weekend I was out Autoxing it and it almost look's like a pcv type valve maybe from to much high revving got a little blow by?
thank you
Ernie
thank you
Ernie
