carburetor guru's????
I have a 72 911E motor with 40mm webbers.
the motor is fresh (<20000km's) and the webbers are as tuned as they can be
The PO left the stock air cleaners on the car as he used it in all weather conditions, where I only use this car on sunny dry days.
I have a constant backfiring issue under deceleration and was wondering if anyone had any suggestions? It's quite embarrasing and is beating the crap out of my exhaust.
I'm using 94 octane fuel. I was contimplating an open elemenet air cleaner to lean the car out a bit but wonder if this will effect the jetting of the carbs too drastically.
I'm new to this whole carb thing, so please excuse my ignorance.
thanks in advance if you can help.
Hi David:
Well sir, installing open aircleaners will affect the jetting so proceed accordingly.
Backfiring on deacceleration can be caused by several things:
1) Mixture too rich
2) Mixture too lean
3) Late ignition timing
4) Heat exchanger and/or muffler leaks
The first two on the list are big variables due to how the carbs are jetted and how well they have been setup; fuel pressure, float level, etc.
Its easy to check the timing with a light and ensure that the advance mechanism in the distributor is functioning correctly.
Any exhaust leaks or pin holes in the muffler will cause the backfiring.
Hope this helps,
1) Mixture too rich
2) Mixture too lean
Hope this helps,
lol...
I noticed the 2 copper gaskets were non existant on the heat exchanger to the muffler, so I replaced them.
I even went as far as to die grind the surfaces clean and smooth before mating the gasket back in.
Backfire gone......
but
now my exhaust leak is more annoying than when there was no gasket left in there at all
Now.... anyone have any suggestions as to what to use with/instead of the copper gaskets? They have been torqued down properly and still leak.
hmpf.
That's the life of a Porsche owner
Backfire gone......
but
hmpf.
Hi David:
LOL,...You are most welcome, Sir.
Those factory copper sandwich gaskets are pretty darned good IF,.................If the flanges are not warped from being overtightened. I would true the flanges with a flat file and make sure that they are indeed,...............flat.
Nothing better in the gasket dept.
