Elephant Polybronze Bushing Question.
Any ideas about how to get all 4 bolts to line up without the binding?
I don't know but I am interested to see how this goes. I have PB in the fronts but not the backs. Can you post photos of what this upgrade takes to do?
If you don't find the answer here, try on pelican tech board because the Elephant owner Chuck Moreland posts there all the time. His handle is the same as his name. Or try PM'ing him.
Good luck bud.
Thanks for the info. With your talent you can do this. It's a little intimidating at first but looking back it wasn't that bad until I got to this part. I'll look through the pics I have butI didn't do nearly as good a job as you've done taking pictures of all the details.
Missed you at the race track last weekend. It turned out to be a good day Saturday and we finished second in class. Not bad for the first time at that track.
Take care,
Doug
http://forums.pelicanparts.com/showt...ight=jack+pads
Keith
'88 CE coupe
edited: PS: I just saw a post on Pelican that Chuck's just had a baby, so he might incognito for a while....Congratulations Chuck!
I have replaced the rubber bushings in my 1966 911 rear trailing arms with the ERP bushings, and they lined up perfectly. Perhaps the torsion bar has taken a set and that is throwing off your bolt holes? I could move the torsion bars in and out of the tube and eventually had to just measure each side to make sure they were in the proper location, as I had upgraded to 27 mm bars.
I also agree that Chuck is willing to assist us in any way to make your installation a success.
Tom
I wound up pulling the inside bushing out then recalking and putting it back together "wet" to dry lined up. That seems to have helped. Also wound up using one of the spacers supplied and one "specialty" washer that is only 1mm thick.
Thanks again.
