2.7 liter engine swap into 71 911
i am about to start on swapping a built 2.7 into my 71 car. i have a 915 to go with it, new msd ignition, coil, wire, tach adapter, solid motor & tranny mounts. are there any suprises or parts that i will be needing to complete before i start? <img src="graemlins/jumper.gif" border="0" alt="[jumper]" />
RL Technical Advisor
[quote]Originally posted by mr henry:
<strong>i am about to start on swapping a built 2.7 into my 71 car. i have a 915 to go with it, new msd ignition, coil, wire, tach adapter, solid motor & tranny mounts. are there any suprises or parts that i will be needing to complete before i start? <img src="graemlins/jumper.gif" border="0" alt="[jumper]" /> </strong><hr></blockquote>
Mr. Henry:
I'd surely suggest a front oil cooler (fender or spoiler mount), an aluminum flywheel and aluminum pressure plate as part of your clutch setup.
I might also warn you that using solid engine & tranny mounts will put a LOT of vibration and noise into the car. The rubber Club Sport mounts are far better for anything but full-on dedicated race cars.
Mr. Henry:
In addition to what Steve suggested:
-915 shift lever housing
-Clutch cable for your vintage trans.
-Electronic speedometer and sending unit (if trans is post '77?; not sure when they ended mech. drive)
-Check CV joint connections between trans and axle. You may have to swap out the CV joint to match the bolt pattern.
-New trans. input shaft seal. You may not want to access this if you have an early 915. Later versions provide access to the seal from the bell housing.
-Large ballpeen hammer (to provide add'l sheet metal clearance for the trans.)
Sherwood Lee
<a href="http://members.rennlist.org/911pcars" target="_blank">http://members.rennlist.org/911pcars</a>
Sherwood Lee
