Slow Window... Please Help.
I have an 88' Targa and the passenger window goes down at normal speed, but goes up slow. It has been this way for a while, no weird noises or anything, just goes up slow. Is motor dying? Or is there something that I can grease, lub etc. Any ideas?
Thanks in advance!
Thanks in advance!
Tough problem to help with, but usually a slow window is because something is binding. On a Targa the problem becomes even worse because virtually everything that can bind is inside the door. I think that it might be panel-off time.
Pete
Pete
I had have the same problem, but only when the temperature is cold. When its warm it operates normal. I think it is a binding issue and temperature makes a difference. I am going to open up my panel also to see what the problem may be
Weather has no effect. It does it warm or cold. I guess I will take the panel off and take a look. JIMQ mentioned spraying the side tracks. I am assuming I need to take panel off to do this??
Burgled
Check the window track's lining. Its rubber with a felt covering to help the glass glide. If the felt's wearing it begins to rub the rubber on the glass that doesn't slide as well. That will then burn up the motor because its working harder to push it up. The other thing to check for are the guides on the regulators. If they're worn the window can **** slightly in the track, which will then wear the felt, and so on and so on and so on....
