Pulled a mis-shift @ the track-tech sessions in DFW coming up! Fri or Sat 4/6 or 4/7?
We had a special one day DE @ MSR with Patrick Long as our lead instructor as well as some of the more accomplished racers locally. Cup Cars outnumbered us "civilians" I think. It was an awesome event!
Except:
One lap after setting a personal best time on the 1.7 mile layout, I pulled the tranny into 2nd from 3rd, instead of 4th. I think I toasted valves in all 6 cylinders, but I'll know more when I get into the disassembly. I'm looking at the brightside, and am going to treat this as a learning experience, and a chance to make a good engine even better. I've been contacted by several people showing interest in participating in the engine drop at least, so they can see how one goes.
I'm going to shoot for dropping the engine next Friday 4/6 (Good Friday) or Saturday 4/7. A lot of people have Friday off, so I thought I'd float that one out there to see if it works. I've got a scissors lift and an ATV lift, so this should actually be a pretty simple drop, all hydraulically assisted. Let me know if you're interested and we'll see what we can set up.
Except:
Wish I could be there Ed.
Any idea what mods you are planning ? Not that it is an engine mod, but I keep thinking a wevo shifter is in my future. The 915 pattern just isn't second nature to me, I fall back to thirty years of italian habits. So far OK, but you have me thinking ...
Glad you are making lemonade.
I'll probably stay fairly mild and just get the compression bump from resurfacing the heads and most likely a cam grind, as well as looking at extrude honing the intake and such. The main focus is to build a strong engine that will be a little more resistant to an over-rev.
A 3.6 transplant isn't totally out of the question, depending on the numbers I work up on a rebuild..
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
Is this a common occurance (misshift)? I have to admit even on semi-spirited street driving I've done the same, but usually just end up "blipping" the redline. I can imagine on a DE or AX where you are running hard at higher RPMs, you end up staying in the "red" much longer before you realize it, which I suppose does "bad stuff"...
What does happen, is grabbing the wrong gear on an upshift or a downshift. In my case, I was passing a car, and was getting over to motion a GT3 Cup Car by, and lost concentration when I was shifting from 3rd gear. In traffic at speed, and I goofed up. Went to second instead of 4th, and had a severe overrev. I caught it pretty quick, but I'm sure the motor saw the high 7,000's RPMS, at least. The valve springs can't keep up, and the valves stay open when they shouldn't, and a piston comes up and says "hi".
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
The other thing is the stock rod bolts probably got stretched, as the pistons travelling at that speed put a lot of strain on the connecting rods.
It seems that many guys racing or tracking their cars regularly experience this at least once in their travels, if not more.
I've never done this on the street, nor at the track with a number of days put in. I felt like a moron at first, but I'm in VERY GOOD company with this mishap. Now, to make the best of it....
A friend of mine did the same thing at a Fall DE and has named the incident a "Money Shift". He just completed the repairs and is still ironing out some issues.
Good luck and keep us posted on your progress!
Ed,
I might suggest you have a look at www.911chips.com
see what others are doing and getting out of a 3.2
I did the extrudehone plentums, bored throttle body to my 3.2
I had EBS do my heads and bore the throttlebody and flow match
my injectors, did the Fabspeed exhaust with the Steve Wong chip.
My mechanic is in Austin, he builds track cars. Have you seen the 72
multicolored 911 ? it is a Peter Max poster looking track car. That is
one of his. Sorry to hear about your car, we had two 911's bend
valves two weekends ago at Texas World Speedway. Race season is
getting off to a rough start !
Chuck
Chuck
Chuck:
Thanks, I've got it Steve W chipped and have headers on it already. I've followed a lot of Carrera rebuilds and upgrades the last few years as well.
I say I'm going to stay "mild" in that I'm not willing to invest in stuff like 3.4 Ps&Cs and twin plugging at this point in time.
Ouch,
If you need an extra set of hands, let me know. I owe you some help and would gladly assist.
