Camshaft questions
Camshaft questions
OK now they are out. Where do you ship them and what do you tell the shop to do?
Send the rockers?
This is a 87 Carrera with 100k miles and is apart because of a broken stud. Found one cyl pumping oil.
Send the rockers?
RL Technical Advisor
Send them to someone who can rebush them as well as grind & true the camshaft rubbing surface.
We can do this for you as well as a few others.
Be sure and use some GM EOS in the oil when you start the engine after the rebuild.
