Install an cold start regulator
I am 'thinking' about installing a cold start regulator which I know I need...and I was wondering if anyone has done this. I have a great mechanic, but I love to do 'basic' repairs.....and I am not sure this is 'basic'....
Yep...it is the Warm-up Regulator.....and this is what my mechanic felt was needed due to hard to start when cold and when it starts the idle fluctuates until warm (120degrees)....It starts quickly when warm.....
You need to have the control pressure tested and compared to the Bosch specific curve for your WUR before you can "know" . Part swapping with CIS is a mistake. Cold start enrichment is performed by the Cold Start Valve and the Thermo Time Switch. The TTS is on the left timing cover and it should provide a ground connection when cold. If the TTS is OK, you need to test the CSV, and this is best done by someone under 3 feet tall. Your engine should run open loop after a cold start below 59F, you can test the temperature switch on the right timing cover and at the lambda test port (green and white wire) with a dwell meter.
Paul
Paul
Wise choice, but ask your technician how he plans to confirm the problem. As Paul stated, a logical, methodical approach is required, parts changing rarely reaps reward. And don't rule out a frequency valve/relay problem, your poor cold start and lousy low rpm running during initial warm-up (I think that is what you're saying) is a classic symptom.
Pete
Pete
