Go to Pelican and look at the picture in their parts catalog. The old rod has a rubber U-joint. The turbo rod is a ball joint. The turbo ball joint is completely inside the rubber boot. The old rubber joint can be see outside the rubber boot. You can see it if you crawl under the car.
