Idling Problem
Idling Problem
I've searched a bit, but most of what I am seeing are cold start problems. Here's my situation:
When the car is cold, it will start and then idle high (around 2,500 or so) for about a minute and then the idle will level out to normal. This all I'm sure is normal.
However, after the car is warm (like after a long drive) the next time I start it, it will idle high again for a minute and then when the idle comes down, it will gradually come down to be close to stalling. It may also hestitate a few times when taking off.
Once I drive in the upper RPM's for a little bit the problem goes away.
Any ideas?
Any ideas?
If we're talking about the '83 SC, your one minute fast idle, at 2500 rpm, is absolutely not normal. Neither is a tendency to stall after a warm start. There are any number of things that could be wrong, but I would start by checking/setting the CO% to factory spec. Depending on what you find determines what you should do next.
Pete
Pete
Pete
Pete
Is it not normal for the engine to run at a little bit higher RPM when it is first turned on from a cold start? And then come down to normal idle.
