Oil Filter Part Numbers?
Rob: The only filter I've ever used/sold/recommended is the Mahle #OC 54. I don't know the 11-digit factory number but if you get a filter at the dealer the Mahle is probably what you'll get. I'm sure that Pelican, etc., also will send you one or more if you specify what you want.
Pete
Pete
I have that in my car now guys (Mahle) but I need to change out filter now for my quick 100 mile run thru to rid of any residual bits in my motor.. just wanted a quick use filter I might be able to pick up and local parts place..and then back to Mahle..
I've witnessed with my own eyes two Fram filters and one unknown filter that were litterally being sucked together by various 911 motors in cars I've looked at over the years.
I would think for the filtering that you want to do, the best filter possible (the Mahle) would really be important at this point. Even a Fram is at least $8 for that big filter isn't it?
If you insist on getting an aftermarket one, then I would think you could find a Purilator or a Champion built filter (such as the STP brand at Auto Zone) that would fit at most any auto parts store. I did a bit of reading on oil filters a few years ago and it seems that Champion (not the plug people - a different Champion) makes pretty darn good filters and sells them to other companies for their labeling. Even the Wal-Mart SuperTech filters used to be Champion filters. I'd take a Champion or Purilator over a Fram...
