side window weather stipping/felt
Can someone give me an idea of how to change the horizontal weather stripping and felt on the door window. I changed the channel felt and that removed A LOT of the chatter I am getting when the window is 1/2 open/closed. I took a quick look at it tonight and it looks as though the black trim on the outside of the door may come off to access the outer piece. The inside felt didn't look to difficult to get at with the door panel off. Any advice?
Thanks...again
Thanks...again
Just did my Horz. window felt. On mine I had to take the chrome trim just outside the window off. Slides off after removing screws. Then take a putty knife and gently pop out the felt strip. Don't let it drop inside the door ! Its held in there with something that looks like 6 or 8 snaps on the strip to hold it against the outer edge of the door sill. recovered it and carefully put it back. Got rid of all the rattles when the door is shut. Also make the window a little stiffer to roll up and down. If you need more details let me know.
