911 Forum 1964-1989
Having issues with idiling
Old Jan 15, 2007 | 06:05 PM
hollywood213's Avatar
hollywood213
Default Having issues with idiling
my 88 carrera is idiling funny, it bounces from 1000 rpm to 1200 rpm, and does this when its hot or cold. i already changed the idle controll unit and the problem seems to be improving, it was jumping from 1000 rpm to 200 rpm and would shut off. now it just goes upwards to about 1200. i had the throttle body cleaned, cleaned out the air filter but wondering what to do next.
maybe the distributor or wires??
thanks
Old Jan 15, 2007 | 06:08 PM
madmmac's Avatar
madmmac
Is it the original O2 sensor? It sounds like it is getting lazy, which is what they do when the get old, swing slower and you notice it.
Old Jan 15, 2007 | 06:18 PM
hollywood213
yes its the original 02 sensor, is it hard to change by myself
Old Jan 15, 2007 | 06:20 PM
J. Brinkley's Avatar
J. Brinkley
I'd unplug it and the ICV and see what happens to your idle. If there's a drastic change I'd look for an air leak.
Old Jan 15, 2007 | 06:24 PM
madmmac's Avatar
madmmac
Very easy. Do it while the engine is cold, you may want to spray some PBlaster on it a day in advance.
Unplug it from the harness in the engine compartment.
Take off the shield and unscrew the old one and put the new one in and plug back in.
Be careful with the new one as to not drop it or beat it up or get any anti seize on it when installing.
You can save yourself some $$'s by getting a generic and splicing it into your plug.
Old Jan 15, 2007 | 06:32 PM
hollywood213
let me see if i have this straight, do i unplug them together or independently? if i do the o2 sensor first and nothing happens, does that mean its bad?? or if it gets worse, i take it my 02 sensor was working??
Old Jan 15, 2007 | 06:43 PM
J. Brinkley
A working o2 sensor will swing your idle somewhere between 30-60 rpms as it works. If unplugging does nothing it doesn't neccasarily mean it's bad, or good.
if it gets worse then your o2 is working, or trying to help the car run at the right mix and speed
doesn't matter if you unplug together or seperate. You're taking the fixes (o2 and icv) out of the equation and letting the car run by itself.
look at the vac diagram on the engine lid and check all the hoses
Old Jan 15, 2007 | 06:56 PM
madmmac's Avatar
madmmac
With the car warm and idling, remove the oil filler cap. The rpm's should drop a little, but the car should still run.
If the car smooths out with the O2 sensor unplugged, you need a new sensor. If it's already over 75k, just change it.
How many miles on the car? Last tune up, valve adjust and air and filter change?
Old Jan 15, 2007 | 07:11 PM
hollywood213
i have about 175k miles on the car, so i think it is a good idea to probably change it
i did a tune up on the car about 100 miles ago
Old Jan 15, 2007 | 07:14 PM
J. Brinkley
at least check the sensor with a meter before you throw it away.
Old Jan 15, 2007 | 07:19 PM
hollywood213
where do you recomend parts from, pelican??
Old Jan 15, 2007 | 07:51 PM
Username's Avatar
Username
To correctly set idle you need to first jump the pins on the test port so as to dissable the idle control. It is my understanding that the O2 sensor will have no effect on cold idle and very little, if no, effect on warm idle. If you need more info on the above I can probably dig up a diagram and instuctions.
Old Jan 15, 2007 | 07:58 PM
J. Brinkley
I wouldn't buy anything until I found the problem. No offense, but the 02 isn't going to fix anything. Most of the time your DME is disregarding the signal anyway. I'd get my car running right first. If it won't run well without it, it won't with it either.
but yes pelican. But there are cheaper places to buy stuff
A local store has a generic sensor that will work if you splice the wires. Having that proprietary plug on the end of it is what makes it expensive.
If you really want to get to know your car get a bosch motronic manual
Old Jan 16, 2007 | 01:58 AM
hollywood213
i'll look for a bosh motronic manual, i think that will help me w/ some issues
Old Jan 16, 2007 | 01:43 PM
ron mcatee's Avatar
ron mcatee
hollywood213, the easiest way to remove the O2 sensor is to jack the ledt rear of the car, put a jack stand(s) under it, remove the left rear wheel for easy access, and remove the sensor. Install is the opposite. I just did mine and used a generic Bosch sensor. I cut the wires and soldered in the new sensor. I also had a problem with idling on my 88 Carrera, but it was idling to erratically and not surging. I finally pulled the fuel rails out and had the injectors flowed and cleaned. Boy does it run good now.
