911 Forum 1964-1989
Distributor Lube/Clean??
Old Jan 12, 2007 | 12:37 PM
A4's Avatar
A4
Default Distributor Lube/Clean??
What is the best product to clean and lube the springs and mechanism under the rotor dust cap? I am changing my cap and rotor and there is dust and crap in there. I hear not to use WD-40 but Cam lube or equivalent.
Also, I do not plan to remove the entire distributor at this time. Just a quick fix for now.
Thanks!
Old Jan 12, 2007 | 01:59 PM
KC911's Avatar
KC911
I don't have a direct answer to you question, but I highly recommend that everyone check out Warren Hall's (Early_ S_ Man) posts on this thread regarding distributor maintenance. For those that don't frequent PP, Warren is like Steve W, Pete Z (and others here)...ignore their advice at your own peril
http://forums.pelicanparts.com/showt...ht=warren+hall
Keith
'88 CE coupe
Old Jan 12, 2007 | 02:33 PM
A4's Avatar
A4
Thanks I read this after searching here and Pelican. All I can find is distributor maintenance for systems with points.
Anyone wrenches out there with advise??
