Fuel Expansion Tan removal
I plan on yanking out the huge washer fluid tank and using the Intensive tank from the 3.2 inside the trunk instead.
http://www.impactbumpers.com/forum/i...expansion+tank
Can the fuel expansion tank be removed and the vapor lines joined togther or is there a smaller substitute tank that can be used?
I want to keep all the dirt & road crud from piling up in the front of the wheel well that will result in a rust issue.
Thanks !
John
Thanks !
John
