87 Carrera Corner Balance results
I had my 87 Carrera corner balanced and aligned. Posting the information for your reference.
Car is 100% stock.
Corner balance done with full fuel load (less maybe 2 gallons), spare tire, jack etc all installed. No adjustment for driver weight or other loading.
Setup is for street bias.
Ride ht is to fender lip.
Corner Balance Wt, Ride height.
LF: 599 lbs, 25.125" RF: 572 lbs, 25.125"
LR: 864 lbs, 25.375" RR: 864 lbs, 25.125"
Rake is about 0.75" when measured to sill trim.
Total weight 2,900 lbs.
Alignment spec Front: Caster 5.7 degrees, Camber -0.6 degrees, Toe 0.05"
Rear: Camber -1.0 degrees, Toe 0.05"
Car is 100% stock.
