CIS warm-up regulator
Team Owner
Benny I dont think such a thing exists
But i have a spare if you want to borrow it to test your car
do you know which one you need ? there were a couple of versions
If you have a Bentely it will tell you . i have the one for the 78 and 79 SC
"can a person rebuild his current warm-up regulator"
There's nothing to rebuild, i.e. all it has is a heater coil and
a flat spring which controls a valve. They rarely if ever fail,
unless someone damages them. All that's usually needed is an
adjustment of the spring based on the desired cold start
control pressure.
control pressure.
Lot's of different WURs over the years. The euro-spec cars had a different WUR so check you numbers to make sure you got the right part. before you make any presumptions about this part, get it diagnosed properly.
