Carrera III 18 inch on a 1986 Cab
No - maximum rears are around 9.5" with a 11-16mm offset
Never see a 10 fit on a earlier car (1978 to 1989)
either way - the bigger offsets will mean 1 1/2" spacer on the front - 2" rear.
Legacy Flounder
Actually, I think it was Bill Verburg here who mentioned you CAN possibly put 10's on the back, but the offset has to be perfect and something (fastener?) needs to be ground back for clearance.
If that’s the wheel tire combo going on there without a spacer in the picture, not really sure 6mm is going to do much of anything. I have learned over the years that there is nothing more expensive and problematic than trying to fit wheels that weren’t intended for the car. A bargain on the wrong wheels always is lots of money and work
