Are the Gremlins playing Frisbee with my dohickee?
5th Gear
On my 86 Carrera there is a round disk with two slots in it located between the climate controls and the steering column. I went to start my car this morning a found mine had disappeared. Can anyone tell me what it is, and where can I get a replacement. Thanks in advance.
5th Gear
I have no way of getting a picture on this board at this time. I have climate control heating system and believe this may be part of that system, as it has a rubber hose attached to the disk. Thanks for your reply.
Did it leave a hole in your dash?? Do you have the automatic heating/climate control? (a **** that runs from 0-9 between the seats rather than two levers and a **** from 0-3) If if the answer to both of those questions is yes then it's probably the hole for the temp sensor for the automatic heating.
Hi,
After just virtually rediesigning this in my 83 targa I can give your the answer. It is the intake for the interior heat senros sniffer motor. The disk I belive was only on the 3.2's and should have a hose running from it to a small motor. In the top of the motor is a heat sensor. The heater works on the differential between interior sensor and exterior sensor (located in flapper box, left rear. The automatic control should then vary the opening of the flapper boxes until the temp setting on the dial is reached and maintained. Simple Ehhhhhhh!
Cheers
Mark.....
Cheers
Mark.....
Old Goat, Mcclure from Australia is correct. I happened to find out sort of painfully that there is a little fan motor under the dash that draws ambient air and ultimately regulates the temperature. Be careful not to put your finger up under the dash near the fan while you are driving. It will startle the hell out of you.
88 Carrera
Spider911
88 Carrera
Spider911
