Roll bar cover removal
I would like to have my targa bar painted professionally. Is it easy/advisable to remove the roll bar cover in order to do this? Can someone please tell me how this is done and if it's a good idea? Thanks!
Before you pay good money to have the work done, you may consider doing it yourself. I was browsing through the tech. articles here and found one about painting the Targa rollbar.
<a href="http://members.rennlist.com/5150targa/page3.html" target="_blank">Painting Targa Rollbar</a>
The operation looked fairly straight forward. It may be a little time consuming to mask everything as suggested and it takes a little fortitude to attack the car with paint, but it looks worth the effort. Cost is quite minimal when done yourself.
Will Ballance
1982 911SC coupe
Will Ballance
1982 911SC coupe
When I painted my bar I first put a coat on without removing the targa bar seal which works ok. I took the masking in behind the seal and the targa bar then draped it down over the seats.
I later removed the seal and painted because I could get a really good coat of paint in the above area.
Also, be very carefull about sanding. You need to do a thorough job of sanding all imperfections or they will definitely show once you start painting.
Lastly, I also tried to remove my targa bar cover and could not get it off. I removed all the attachment points in the wheel well and along the front of the bar under the seal, but it would not budge. I think someone may have dumped some type of glue somewhere. I really made a mess of the whole deal. I would recommend leaving it on also.
Good luck!
Michael
87 Targa
Good luck!
Michael
87 Targa
