Moisture in Door Panel Question....
I noticed that moisture (after washing the car for example) via condensation is present between the horizontal rubber part that is on the outside of the door window. As I just got the 911, I am not sure if this is a problem or natural for the car. Should I be checking a seal or something? Thanks, Andrew
Hard to envision what you're asking but if there is a valley area inside the seal, all my cars get some moisture there. What year 911 do you have, what type (coupe, targa, etc.) and which seal are you speaking of? I assume no moisture is getting inside the car? If so, and you're speaking of the top seal, maybe the window just needs adjustment.
