911 Forum 1964-1989
Balky Gear Shifts
Old Nov 16, 2006 | 01:30 AM
carnick's Avatar
carnick
Default Balky Gear Shifts
My '88 Targa has been difficult to shift recently from a cold start. At times it takes 8-9 attempts to go into reverse. I usually park it in 1st, then go to neutral to start, then to reverse. It's been "stuck in neutral" lately until I finally find 1st then run on through to reverse. Could this be due to temperature changes? Could it be low transmission oil?
Please help!! Thanks!!
Old Nov 16, 2006 | 06:18 AM
Shahrams's Avatar
Shahrams
or old transmission oil. Changing the oil would probably help.
Old Nov 16, 2006 | 12:18 PM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Carnick:
How long has it been since the clutch hydraulic fluid was changed?
Is the slave cylinder original?
Do you have a good synthetic oil in the transmission?
Old Nov 16, 2006 | 12:56 PM
Peter Zimmermann's Avatar
Peter Zimmermann
Thanks, Steve! I was just going to post the same questions!
Pete
Old Nov 16, 2006 | 01:48 PM
GeneralTso's Avatar
GeneralTso
I don't have an air cooled Porsche (yet), but on many other vehicles that balked at going into reverse, it helped to push in the clutch, move the gearshift to 3rd (without lifting off the clutch), move the gearshift to reverse, and THEN realse the clutch. I'm not sure why, but it's helped on everything from CJs to MGs...
Old Nov 16, 2006 | 03:57 PM
IslandmanPA's Avatar
IslandmanPA
It gets the syncos and all the gears spinning at same speed!
Seller of fine used halon and halotron fire extinguishers!
Old Nov 16, 2006 | 04:05 PM
GeneralTso's Avatar
GeneralTso
You work upstairs from me, don't you IslandmanPA?
Old Nov 16, 2006 | 04:13 PM
IslandmanPA
Did you recognize my mug? ;-)
Old Nov 16, 2006 | 04:14 PM
IslandmanPA
I'm further SOUTH. Near Pittsburgh!
Old Nov 16, 2006 | 04:17 PM
GeneralTso's Avatar
GeneralTso
HAHA....Got it.. I thought maybe you were the guy who works upstaris from me... I've been telling him how great Rennlist is for the past month or so...
Sorry for the diversion, Carnick!
Old Nov 17, 2006 | 01:39 PM
carnick's Avatar
carnick
Default Thanks -
Thanks everyone and all! Looks like I have some work to do this weekend. I had planned an engine oil change - now I'll add the transmission changes.
See ya!
Nick
[FONT=Tahoma]'88 Targa
Cassis Rot (Red Current)
97K Miles
Old Nov 17, 2006 | 05:27 PM
theiceman's Avatar
theiceman
Team Owner
be warned .. I find that transmission oil really stinks when changing it , for some reason it has a really acrid smell..
Old Nov 17, 2006 | 06:10 PM
fixnprsh's Avatar
fixnprsh
When you put it in 3rd with the clutch pushed in, it stops the input shaft so you can get it in reverse, BMW's VW's and Porsche people use this trick to get it into first at a stop sign when the syncros start to go south.
