can any one with an sc help ? particularly a 78
Team Owner
I was underneath the car once agaon working on the valve covers when I noticed what looked like a twig sticking out by the light assmbly up underneath the fender on the drivers side. I pulled on it and to may amazement came down this 2 ft long wiring harness with 2 wires in , a white with red stripes and a solid white I think. I have no idea where it used to go. Up by the light from underneath the car I see the wiring budle which four harnesses come out, one goes to the drivers rear light assembly, one is a bunch of 3 ground wires, and one runs to the rear bumperette for the license plate light, the forth is my mystery harness, does any one wkow where it goes or can check it for me please .
PS is that "PORSCHE" rear piece just a reflector or a light ? maybe that is it ? even though I see no light assembly...
Thanks.
Thanks.
Could it be the wiring for a rear fog light that isn't there? I think they usually mounted below the bumper on the left side. Does your fog light switch rotate as well as pull out? I think that rotating the fog light switch activated the rear fog light on cars so equipped.
Team Owner
My SC does not have fog lights so that ain't it :-)
Unless everyone has this wire and only the cars with fogs use it ?
James can you see anything withthe engine out ?
maybe I should check to see if I have voltage with the lights on , that might tell me soemthing
Ice,
My engine isn't out yet. But I just looked under my car and I am pretty sure that the twig is the wiring to the license plate light. My car has a twig on the other side too. I bet you driver's side light doesn't work anymore.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Team Owner
Hi JAmes it does not go to the lisence plate light, where I see the wire bundle 4 harnessess come out, I will see if I can get a pic, one goes to the plate, one is a ground, and one to the rear light asembly . So that leaves me with this trange extra..
Maybe to the little light just to the right and left of the Porsche sign? Look at your avatar. I forgot how to turn those lights on. Probably reverse, but I can't do that one alone! I think those lights turn on with the hazard light button.
