Converting clock gauge to vent outlet.
Came across a kit from SmartRacing Products in the latest issue of Panorama that routes fresh air ducting though the clock opening, converting it to a fresh air vent. Anyone try this?
Also, when stationery with the windows down I can sometimes really feel the heat coming from under the car. Would the Heatshields that attach to the valve covers reduce those temps?
If you're feeling heat coming up, it's probably because your flapper boxes aren't closing all the way.
So long as your heat exchangers are connected normally, I don't think heat sheets would have any effect on the situation.
