Fuel Gauge problem?
Has anyone else experienced a problem with your fuel gauge registering just fine until it gets down to 1/2 tank, and then who knows what until the low fuel light comes on. The low fuel light is coming on at the right time, but nothing between 1/2 and almost "E". This is on an 83 cab.
Originally Posted by theiceman
I replaced my sender because of this , along with a new cork gasket.
Team Owner
very simple.. almost embarassingly simple. disconnect the battery to be on the safe sid e.. well okay I didn't. lift the front carpet in the cargo area , take the electrical connector off, undo about 6 nuts on the sender, ..remove and install new sender with new gasket..
