911 Forum 1964-1989
Replacing Drive Shafts
Old Oct 9, 2006 | 08:15 PM
Credit_Card_Guy's Avatar
Credit_Card_Guy
Default Replacing Drive Shafts
I am thinking about replacing the drive shafts on my 74 911s. Can anyone give me some insight? Is this a large job, small job....
Old Oct 9, 2006 | 08:45 PM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Kevin:
Its pretty easy as long as you have the right tools and a dash of patience.
You'll need:
1) A pair of new driveshafts
2) Extra grease (I like Swepco # 101)
2) A good torque wrench
3) New CV bolts and Schnorr washers
4) 4 gaskets
5) Lots of clean rags
Old Oct 9, 2006 | 08:51 PM
theiceman's Avatar
theiceman
Team Owner
don't forget some clothes you can throw away and some thin latex or plastic gloves...makes it a much nicer job. that CV grease is messy but I quite enjoyed the job.
Old Oct 10, 2006 | 08:30 AM
Credit_Card_Guy
Anyone have a link to a discription of the job?
Old Oct 10, 2006 | 08:41 AM
redtdi96's Avatar
redtdi96
Since you have it all apart, are your rear bearing OK, check for noise of shaft play. Great time to replace the bearings
redtdi96's Avatar
redtdi96
Since you have it all apart, are your rear bearing OK, check for noise of shaft play. Great time to replace the bearings. But then again you will need some very special tools
Old Oct 10, 2006 | 10:52 AM
Credit_Card_Guy
Bump -- Looking for some direction on the process of replacing the drive shafts. Anyone have a link to a tech section on the subject?
Old Oct 10, 2006 | 11:04 AM
911 Rod's Avatar
911 Rod
Why are you changing them?
Worn splines?
Or, are you referring to the CV's?
Old Oct 10, 2006 | 01:18 PM
Credit_Card_Guy
Boots and CV's need to be replaced. Figured it was just as easy to buy the completed drive shaft (everything already together and ready for install) than to try and replace the boot and CV.
Old Oct 10, 2006 | 04:13 PM
theiceman's Avatar
theiceman
Team Owner
What do you need for a procedure ? unbolt the old ones, put in the new ones. Pelican may have something but it is VERY straight forwad
Old Oct 10, 2006 | 04:19 PM
r911's Avatar
r911
Anti-Cupholder League
There is a very extensive description of everything involved if you do a seach on Pelican - be sure to put CV in the search too.
There are several things that are absolutely critical to do - just bolting them in is not enough unless you do it right.
