Rubbing noise in front end
My 80sc has a rubbing noise from front end while driving I,ve checked all the possible things, brakes,wheel bearings, to no result put it back on the ground and drive it and sure enough is back I can feel it coming right through my steering it almost seems to go away if slightly touch the brakes but they, are free nothing sticking, vehicle has being lowered any help ideas please.
thanks
Ernie
thanks
Ernie
Ernie: A recent post regarding correct caliper piston positioning (the 20-degree step) could be the cause of your noise. Also, have you checked the dates on your brake fluid hoses? If they're older than ten years they should be replaced. Many times, during a physical inspection, brakes may seem to be "free," but that's not always the case. Your mention of a subtle improvement when touching the brake indicates that you probably (1) have inferior aftermarket brake pads, (2) have a caliper-related problem, or (3) have a fluid hose related problem.
Pete
Pete
