Weltmeister Cambermeister
Has anybody had problems with this strut brace on 3.2 cars? After instalation and a short test drive my left strut sheared off. ( see earler post). My new Bilsteins are coming and am not shure if I want to use this brace again. This is the type that also bolts to the large nut on the strut its self and the two bolts on the strut tower.
Technical Specialist
Lifetime Member
Lifetime Member
I used the Weltmeister strut bar on my 81SC (basically the same suspension as your 3.2 Carrera) with Bilstein inserts for several years, which included 15+ track days each year, with no problems.
I have the same experience as Bill. I have used a Cambermeister/Bilstein Sports on a '84 Carrera for 3 years (10 track days per year) with no adverse results.
Could your problem be related to excessive pre-load on the cross bar?
Bruce
Bruce
There was very little preload on the crossbar. Just a very slight pressure by hand towards negative camber. And a mean very slight pressure. I guess I had a bad strut, I am very thankfull that it didn't happen at the track. Thanks for your input.
