Tool Kit?
Stan,
Images are too small - looks like a couple of extensions and I can't make out what the spring attached device is. IF it is from a 911, it must be a very early one, because it has about a 1/4 of the tools found in my '81 kit.
Team Owner
Actually that COULd be from a 356 ... I saw one or 2 at a show and the pouch was the same color, I the spring device I am pretty sure is the plug removal tool ( allows to bend around . ) . I think the bar goes through then end for leverage.
The PET has a pretty good description of the tool kit. Might get a few buck s for it on ebay , or somebody here might be interested if you are selling it .
My bet is that it's for a 944 - year unknown but probably early. Six pouches make it very possible. The large straight rod turns the 17mm x 19mm socket, and the smaller rod turns the spark plug socket (with the spring). I think that the kit should also have an open end wrench, 10mm x 13mm, as well as a small screwdriver that can be changed from a flat blade to a phillips head.
Pete
Pete
