Difference between 911/93 & 911/93 engines
What are the main differences between 911/83 & 911/93 engines? If my ustanding is correct, 911/83 are RS engines?
Is it possible to to convert a 911/93 engine to an RS spec'd engine and if so, what are needs to be done for the conversion?
And lastly, how reliable is an RS engine (as compared to 911/93 engine)
Thanks for your help
RL Technical Advisor
Hi:
The 911/83 engine is the 2.7 RS MFI-equipped, 210 HP motor found in the '73 RS and Euro '74 Carrera's. Some '75 Euro Carrera's had this engine, too.
The 911/93 engine is the 2.7 CIS-injected, 175 HP (DIN) motor found in US '74 911A & Carrera's.
Its possible to convert one to another, but its NOT cheap anymore. You'd need a complete late MFI system, machine work on the heads, different cams, some sheet metal and a host of small details.
These engines are quite reliable as long as oil temperatures are VERY carefully controlled.
steve
thanks for your quick reply.
when you say oil temp has to be VERY carefully controlled, what do you mean by that? btw, i live in a very hot and humid climate (365days of 90degrees + 90% humidity). what should one do to control the temp? extra oil cooler?
what about the reliability of a 911/93 engine assuming it's fully rebuilt
thanks
thanks
My pleasure,...
Given your climate, you will need a big oil cooler in the front fender with a fan and lots of air ducting. If you keep a mag-cased engines' oil temps under 200 deg F, these last a LONG time. I use either the factory cooler setup (Carrera 3.2) and make sure that air can reac hthe cooler from the front of the car; something thats usually overlooked.
IF,..............IF,..a 911/93 motor is rebuilt correctly and low oil temps are maintained, these are quite durable. The key is preparation and assembly.
