911 Forum 1964-1989
OUCH!!! Had to be towed home - what could the problem be?
Old 08-16-2006, 06:10 PM
marcandkimmie
marcandkimmie's Avatar
Originally Posted by madmmac
Sorry, I meant DME relay.
If your cat got that hot your O2 sensor is probably literally toast. Cats can take a tremendous amount of heat.
You do have gas in the tank right???
Yes, there's plenty of gas in the tank. Thanks for the info on the CAT. I will replace the O2 sensor if it is bad.
Old 08-16-2006, 06:12 PM
marcandkimmie
Originally Posted by My87Targa
have you pulled a spark plug and chacked that yet or checked your cap and rotor??? those were the problems ive had in the past.
Yes. I actually replaced all those recently so they are good. I rechecked the connections just to make sure.
Old 08-16-2006, 06:14 PM
marcandkimmie
Originally Posted by J. Brinkley
after DME what about CHT? that would be my first check if it's original. does it start cold and not hot?
What is a CHT? The car does not start cold or hot.
Old 08-16-2006, 06:24 PM
madmmac
madmmac's Avatar
C=cylinder...H=head...T=temperature sensor.
Get the DME relay first to start with....as stated, it's always good to have a spare.
Old 08-16-2006, 08:46 PM
marcandkimmie
Thank you very much.
I really do appreciate all the help.
Old 08-17-2006, 12:03 PM
Giantviper
Giantviper's Avatar
My dad had his DME relay go on his 86 once it sucked. the car basically died. Now we both carry an extra one in our glove box (I have an 88 944).
Old 08-21-2006, 10:32 AM
marcandkimmie
UPDATE 8/21/2006.
I replaced the DME relay and unfortunately the car still won't start. I will have to tow it to Omega Motorsports here in Jacksonville so Steve can figure out what is wrong.
This car has 243,000 and has been ultra reliable until now. Oh well, we'll see what's up. I miss driving it terribly.
Old 08-21-2006, 10:52 AM
g-50cab
g-50cab's Avatar
My guess - Bad reference sensor on the flywheel. They get heated and cooled - insulation cracks and bang - no signal back to the DME. Relay was a good thing to replace- now keep the other in the glove box.
I'd replace all three sensors while you can - It's pricey - but they are subjected to alot of heat and such.
Old 08-21-2006, 04:24 PM
marcandkimmie
Thank you Jeremy for the advice on the refernce sensor.
With the engine at 243,000 I'm starting to wonder if it could be an internal problem?
What do you think?
Old 08-21-2006, 05:27 PM
g-50cab
g-50cab's Avatar
If the plugs looked OK - then no - usually an internal problem is proceeded by a bark, bang or knock and then lots of smoke.
Assuming it will still run over -
Old 08-21-2006, 08:04 PM
DonMo
DonMo's Avatar
I vote for the Cylinder Head Temp. Either that or maybe a reference sensor. Both easy to check. Check ohms on the CHT (left side of engine by blower, it is the white connector on the top of the three connector tree). Ohms should be around 1.5k at summer temps. The reference sensor will be a little different, the wires usually tell you if it is tired. You know, cracked and falling appart. If the cylinder head temp is the problem. You can jumper the connector with a paper clip once the car is warm and it will run fine.
Old 08-22-2006, 09:49 PM
marcandkimmie
Thanks guys. There was definitely no bang or knock and definitely no smoke. I'm glad to hear that!!! I can handle electronics.
I love this site. You all are great.
- Marc
Quick Reply: OUCH!!! Had to be towed home - what could the problem be?
