Pls HELP, VR replaced, damaged pully
Helo:
I replaced the VR on my 87,after put the fan housing back and bolted all nuts, I did not realized that the fan housing help to be behide the V belt pully, now the pully is damaged. I read the Bentley maunal and see if I can replace the pully, but there are no info on this.
Any one know how to remove and replace the pully, please help me
Here is the picture of damaged pully of my car
<a href="http://boards.rennlist.com/upload/DSC00021.JPG" target="_blank">http://boards.rennlist.com/upload/DSC00021.JPG</a>
If you are talking about the crankshaft pully, which I assume you are, then the engine will have to be lowered to remove the support bar and pully cover.
Sorry about the damage, but you have some work ahead of you.
Yes, the crankshaft pulley is damaged, lowered the engine is NOT what I expect, any idead what is cost if I have the shop do it, hour of labor & part ?
