Do all brands of "ZR" rated tires have the same side wall strength? Is there a standard in the industry that all or most manufacturers go by when producing these rated tires. Why you may ask? I recently changed the brand of ZR rated tires on the rear of my '86 and I would swear that it feels noticably "fishy or loose" at the back end. Now, my car is lowered (and has been) to euro specs and I have gotten no rubbing but it just seems a bit loose. Old tires as well as new...255/45 ZR17. Call me crazy but could it be the side wall strength?? Could the new rear be showcasing another problem??? Hey Pete, any ideas. Anyone with some ideas...please chime in. I'll let you in on the brand changes if needed after some dialogue begins. Thanks guys.
There is a break in period on tires, granted its just a few miles.. how long have they been on? Maybe you need to run a different pressure on them? Does it feel like they are rolling over the rim? Maybe you need a bit more pressure. ZR tires can have different compounds, i.e. treadwear ratings. What kind of tire are they?
Also remember new tires have the full tread block , any racer who runs with shaved tires will tell you the steering response is better once the block has worn down . Tirerack has a good write up on this subject ( tire break in )
911's are quite sensitive about tires due to the car's weight distribution & dynamics.
I've always had problems with having two different brands and/or model tires on each end of the car and I'd strongly recommend that you run matched tires, even if the fronts are still in good shape. The car will not handle right until you do,...........
Bet you lunch that installing the same brand and model of tire will fix your woes,...
I agree with the matched tires. I recently had to replace the rears on my SC track car, and everyone I talked to said replace all 4 if I wanted a different brand, or match the rears to the fronts if I only replaced the rears. The Tire Rack was able to find a pair of rears which I put on. The "break-in" period was 500 miles to "scuff" them in, get rid of the mold release material, etc. I went out of my way to drive extra miles, as I had a DE at Sebring that next weekend. I noticed a significant difference in the feel of the car at track speeds with the deeper tread on the rears. I could feel the "squishiness" of the rear tire's tread depth in all of the braking zones, turn-in, and track-out. In short, the car felt noticeably more unbalanced at the rear.
