Choosing a ducktail - difference in quality?
After picking up a carrera tail replica off e-bay recently, I've decided that my 78 will look better with a duckie tail.
Now, fiberglass versions are to be had for $299 from Performance Products, but I have seen carbon fiber versions for $599. I assume these are for racers who want to minimize weight.
In your opinion what is the best quality duck out there?
Ulrich
Ulrich
RL Technical Advisor
Hands, down,..by FAR, the factory ones are the best. These have a steel frame inside them.
Aftermarket ones always take a lot of work to fit, but the ones from Getty Deisgn are very good.
This is my ducktail from Rennspeed....at the time i got it....$299 plus $60 for shipping to GA....it did take some prep work by the shop to get it fitting just right....but the labor was really fairly inexpensive....I also had some other paint work and other issues so actual finished cost isnt readily available....but this is the second ductail I purchased....the first one was more expensive and was actually harder to fit and needed much more prep than this one did....I am very pleased with the final product.
Yes they were pre drilled with aluminum inserts to use all factory hardware.....the other lid was from AIR several years ago. I agree by the way the factory lids are by far the best....but I can buy a lot of replicas and spend a lot of money getting a proper fit for what one of those cost...and the fiberglass wont separate from the meteal base at some point in time....you also have to be aware there are a couple replica lids that have an improper side profile to them....I can't remember which lid that is off hand....I can tell you the lid from Rennspeed has the correct side profile....as does the one from MA Shaw at about twice the price...fwiw
I've heard that Getty Design and MA shaw ones are the same. MA Shaw's are made by Getty Design. Can anyone else confirm this?
Love the Duck on my '78 too! The world needs more ducks
