82 exchangers for 78sc
Team Owner
I will be getting some 82 exchangers for my 78sc and from what I have seen they are different . I think the 82s use a thin flange and the 78 is the thicker flange. I have heard of spacers for this. Does anyone know if I am correct in this and where i could get the spacers if that is what I need ?
Thanks.
Thanks.
It's the other way around - 82 used thick flange.
The idea of using spacers to get the thin flange HEs to work on a car that needs thick flange is a real hack, would not recommend it.
Are you installing stock heat exchangers? If so they are readily available used, cheap.
no - as I said above they won't fit right. Shimming them is a hack and will screw up your muffler attachment locations. You should buy some from a 78 or 79 SC.
Or better yet, upgrade to an early style exhaust (i.e, SSIs), unless smog restrictions keep you from eliminating the catalytic converter.
If you REALLY want the original style heat exchangers, post a "want to buy" ad over at the Pelican site under " Porsche 911 Used Parts For Sale & Wanted". Make sure to indicate 78-79 SC only. You will have plenty of people respond who would be happy to sell you their old heat exchangers cheap . They have all upgraded to SSIs or headers.
For reference - on US 911SCs, 78-79 = thin flange, 80-83 = thick flange.
Cheers,
Jeff
Cheers,
Jeff
Team Owner
Thanks jeff
II just thought if it were the flanges where it ataches to the head I could replace the studs with longer ones and be fine. Oh well.
