Homologation '76 Carrera 2.7
Here's a very interesting and detailed thread that will educate more than a few people about some special 1976 Carreras that aren't very well known...
http://forums.pelicanparts.com/porsc...7-carrera.html
Look at this thread on the Early S board, especially post #10. The poster, xenifizi has one these '76 Carrera Targas. I have his direct email if you would like to contact him directly.
http://www.early911sregistry.org/for...ht=Gendarmerie
7th Gear
There is # 15 registered on this site by Johan (xenifizi?) in Belgium
http://sigierca.cluster010.ovh.net/froggy/aindex.html
#26 was for sale in France last year, Jochen has #30 and there is the D'Ieteren one so it seams at least four of the twenty remain.
Guy
Guy
The 74-77 Carrera's built the type 911/83 motors are not RS's. They are great cars however and until about 5 years ago were fairly inexpensive. They were not built to homologate anything but to consume an existing stock of 911/83 engines. There is a lot in that wikipedia post that is not correct.
Phil
Phil
Your comment about homologation holds true for the '74 and '75 Carrera 2,7 cars but is incorrect about the '76 Carrera 2,7 coupes built. These 113 coupes were built late in the '76 model year for homologation purposes and these cars were homologated as an RS model in CH and Germany.
I am in the process of restoring a #'s matching, certified example at CPR. It's Conti Orange with Black/Tan interior. They also have a brown one restored by Porsche for sale. These have VIN#'s that precede the RSR of that year and they are mentioned in The Porsche Book (Boshen/Barth), the bible of Porsche classics.
Many confuse these with 2.7 Carreras of the time... that 2.7L had a different fuel injection system. The 76 RS' had the original MFI of the 73 RS' to allow more modification for racing. And they featured the same 73 RS fenders, had cage base-plates welded from factory, RS brakes and lightweight suspension. The standard 2.7 Carreras did no have a wing. The 76 RS had a whale tail wing.
See CPR's example here:
http://www.caporsche.net/images/cars...pe/images.html
IMO, these are some of the rarest road-going 911's and should be worth close to the 73 RS' as more collectors learn of these cars. Porsche's that are rare are valuable and they made 1,500 73 RS' and only 120 76 RS'.
7th Gear
There were in fact only 113 examples made as I had it confirmed by the factory that chassis numbers 1-10 were not used. I was looking to buy one in Holland three years ago but missed out and ended up with a '74 Euro Carrera instead which I am restoring. The '76 Carrera 2.7 RS MFI is identical to the '74 and '75 Euro Carreras apart from the galvanised chassis, a 915/43 transmission with LSD instead of the 915/06 with the option of LSD, electric windows as an option wheras they are standard on '74 and '75 cars and the electric drivers flag mirror although this did appear on a few of the late '75 cars as well. Of the examples I have seen only half seem to have the rear whale tail and half don't and the factory doesn't have any of them listed with the spoiler option M473, so bit of an unanswered point there I think. There were 1026 '74 and 508 '75 Euro Carreras produced so even if these were included in the total production it would still only be the same number as the '73RS. The '76 was however as Brian says homologated as an RS and produced as a 'special model' so I think it does command a premium price wise and they don't normally appear to hang around when they come up for sale. You certainly have a very desirable car there, good luck with the resto and I look forward to seeing some photographs.
Guy
Hi Dude,
Guy
Guy
Yes, I have known of the brown Carrera for a number of years. Nice looking color combo, especially the seat inserts. Congrates on owning and restoring an orange model. Great color, one of the best IMHO.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I too would enjoy seeing photos of your Carrera. What # do you have? Like Guy, I have seen several cars over the years without rear spoilers so not all had them from new. I am curious about your comment about the MFI. How is it different from the '74 and '75 cars?
As to value, I too think they should and will have a premium over the '74-75 cars, but disagree that they will approach the '73 Carreras. I could be wrong though so we shall see.
As to value, I too think they should and will have a premium over the '74-75 cars, but disagree that they will approach the '73 Carreras. I could be wrong though so we shall see.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
7th Gear
Hi Dude,
California seams to be bit of a hot spot for these cars, #13 is in Los Angeles, #50 is also being restored (San Diego?) as well as the brown one #43 that you posted.
I note in another post you mention welded in plates for a roll cage which I believe Brian has also mentioned for these cars, have you uncovered these on yours?
A few other small differences between the '76 and the '74/'75 MFI are an aluminium front crossmember instead of steel, cast iron 'A' front brakes instead of aluminium 'S', adjustable rear spring plates, 6 bolt CV joints instead of 4 and a permatune CDI box.
Guy
Guy
Hi Dude,
Guy
Guy
As for my car; apparently it was owned since new by a former Air Force pilot that was stationed in Germany at the time and he brought it with him to CA. It has no rust and has never been in an accident. However, it currently sports an awful candy-apple red paint job, but the interior is 100% original and is a beautiful mix of black and tan. One interesting note, is that the COA does not mention A/C, but my car has factory A/C and also has the front/rear spoiler package too, which also isn't on the COA. Seems COA is only good for matching #'s, but not options on these cars.
Cheers,
Laguna_Dude
Very interesting. I was not aware of any of these differences. I wonder why the brakes were not AL. Seems strange to me. Thanks.
So the key variables I want to confirm are:
1.) RS fenders (visually they look like they are)?
2.) RS brakes (vs. Cast Iron Type A)?
3.) Factory-installed cage mounting plates?
Here's the link to the one CPR has for sale noting all these extras that make it an "RS"... I have no reason to doubt CPR, as the owner, Brian, has first hand knowledge, as he worked in the Porsche factory during the 70's: http://www.caporsche.net/images/cars...pe/images.html
7th Gear
Brian, Dude,
Most of the differences were just later production parts but as you say the aluminium calipers were still being used on the Turbo 3.0 I haven't got any photos of the calipers on #43 at CPR but all the photos of other cars I have seen have the A type.
As for the COA it only shows the options that were not standard eg the LSD is not listed. I would have thought A/C would be though although I know of one with a sunroof which is not shown on the COA. Another difference with the '76 cars is that chrome look trim was standard with black an option rather than the other way around for the '74 & '75 cars and indead the Carrera 3.0 at the time.
The RS fenders are another interesting point as I believe (and Brian will be able to confirm) that the '73 had a tapered lip being thicker at the top. The has been some discussion that this continued for the '74 Carreras or even '75 but the Carrera 3 has the near equal lip alll the way around like the SC. I would have thought the '76 C2.7 would have had these same fenders fitted down the production line.
The cars were definitely a special series and all produced near the end of the '76 model year nearly a year after the '75 Carrera 2.7 had been out of production. Supposedly they were supplied in Germany and Switzerland although ones I have seen details on have all been supplied by German dealers.
Guy
Guy
Guy,
I actually have never seen one of these Carreras in person so I am not really sure about which flairs these came with originally. Based on photos I have seen I think they seem to resembled RS flairs but I'm not a 100% on that.
Here is a link to a RHD car, #107. Have you seen this one before? It was the subject of a thread on RL many years ago. The blog writer mentions he is not sure why the rear badge is missing, but I remember that the original thread mentioned it was missing because the rear lid was damaged by something heavy falling on it. The repair was done but the owner at the time didn't bother to put the Carrera badge back on.
http://motoring-projects.blogspot.co...20carrera%20rs
