rusted studs .... oh crap ...
ice: The studs you need are 8mm x 20mm. Also, I couldn't see flat washers under the nuts in your photo, put one on each stud before you put it together...
Pete
Pete
Team Owner
Thanks Pete
Do I put the studs in the transmission with some type of loctight ? There were no washers on at all. I was just going out now actually to get some new hardware , but getting metric hardware is diffcult here , especially on a Saturday ...
Team Owner
Found some 8 X20 studs so I decided to finish up , Cleaned up the brace and it was all just paint peeling and surface rust.put it through the wire wheel , put a good rust primer on and topped it with whatever I had lying around. I am going to put stainless nuts on the brace but I put plated crap ones on for now.
Things are progressing niceley ,,, now I know I said i was done Rod, but those exchangers just HAVE to go .... someone hand me the pb blaster :-)
Hey, new brake hoses, new Sport Bilsteins, new CV joint boots (with new clamps!), new (?) sway bar, new clutch cable, really unusual trans mount!... egad, look at that exhaust hardware!
Pete
Pete
Team Owner
Gee no wonder I can't get any heat ! its all pouring out those holes and cracks ...I want to put SSIs on but it is a little pricey for this year and I am nervous about the studs, maybe I will soak them over next winter .. by the look of thid car you would think I never drive it .. just continually work on it ..hmmm..
ps resprayed sway bar but new drop links. oh by the way i have a question about that . should the end of the sway bar pivot on the drop link ? mine does not . but I would have imagined it did . When I tighten the nuy it grps the sway bar. The reason I ask as that if it grips it hanging, it will be under more strain when I lower it off the stands as the geometry changes and the sway bar is gripped with it hanging ....
Rennlist Junkie Forever
theiceman
I've got a nice set of heat exchangers you can have with cross over and muffler for $150+ shipping from Los Angeles.
That's a good deal!
TonyG
That's a good deal!
TonyG
Team Owner
Hey Thanks Tony , you are helping to contribute to my 'continually working on my car . but never getting to drive it fund " .. I'll take them and PM you ..
Thanks.
Thanks.
