Updating to SSIs. Clutch lever clearence.
Just rebuilt my engine and backdating to SSIs. After discovering multiple "mods" that need to be made, ( oil lins, heater hoses, etc) now it appears that my clutch levers won't clear the heater box. Am I missing something or do I need to get the die grinder out?
Thanks for the input.
1 Post
you can do two things, cut out the stainless steel around the area at the front of the curve on the left heater box untill it clears, then take it to a shop and have a patch panel made to cover up the hole and make it look nice.
Or you can flatten the skin into the inner tube with an air hammer with a flat nose tip if you are in a hurry ir if you dont care.............
