911SC Steering Bearing
Thanks in advance for any help!!!
Dominic
There is another universal behind the gauges where the shaft from the smugglers box needs to change direction to come out of the dash straight.
When I used to work for a living, we had a bearing puller that had three thin fingers with notches in them. The fingers would go into the ball bearing between the inner and outer races and the middle of the puller would have a threaded bolt that pushed on the end of the steering shaft.
Failing that you could undo the top universal joint, the bolt that holds the steering lock to the steering column, the bolt at the back of the steering column (under dash pointing up) and the two bolts that are accessable from behind the gauges(pointing down), and remove the whole thing.
That's what I would do, but you will have to remove the wiper and indicater stalks and the plastic shroud around the column.
I hope this isn't written too confusingly. (is that a word?)
Cheers
Frank
Good luck!
Thanks for the info and the link. I spent my weekend covered in grease and grim. I did the Turbo Tie Rod upgrade, put in new front wheel bearings, rebuilt the calipers and painted them, put on some nice, new. drilled rotors and Ferodo pads, and installed the pop-off valve in the airbox. I wanted to do that steering wheel bearing, but after the grocery list above I was ready to explode when I saw how involved the steering bearing project was going to be, and I was seriously running out of time. I ordered the sleeve from Pelican this morning, and I will be putting that in this coming weekend as well as the shift couplings. I guess there aren't enough hours in the day. Thanks again.
Dominic
