Front oil coolers
I have never seen an auxillary oil pump (perhaps they use them on race only cars?) used on a 911 when using a front oil cooler? Has anyone ever seen a engine (not chassis) dyno test studying the "pumping" losses (H.P. loss) on a 911 ...to push all that oil, through all those additional lines?
RL Technical Advisor
"Mo":
The engine's oil pump (two-stage dry sump) has plenty of capacity to circulate the oil in these systems,...
Thats why you never see any external oil pump on a 911.
One chooses the proper oil pump (Carrera-Turbo-GT-3R) for the engine and how its to be used. Pumping losses in the 911 engine are due to windage and there are a whole host of modifications to reduce/minimize that.
Rennlist Junkie Forever
Steve Weiner-Rennsport Systems
>>>One chooses the proper oil pump (Carrera-Turbo-GT-3R) for the engine and how its to be used<<<
Out of curiosity, are the above pumps (or some of them) interchangable? In otherwords, which pumps fit into which cases (not a complete list... but any of the "common swaps").
Not that I'm in need of it... but it would be good info to know.
TonyG
TonyG
